Perimeter not connected big gaps, big .STL file
Hello,
Its realy big print 600x400x450
Why slicer is doing that ? Sometimes it makes good perimeters sometimes not with same profile..
PC settings :
intel i7-7820x
48gb ram
Quadro P4000
Best Answer by Karolis S:
Added option :
Before Layer Change in printer configuration :
G92 E0
Still cant understant why sometimes it worked. 😀
Project file please
For any reasonable help we need your project file. There are far too many things that could impact slicing. You need to File>Save Project then take the resulting .3mf file and zip it into an archive. It must be zipped for the forum to accept the file type.
With a project file we can then see all your settings in use and debug things with much easier. Its a snapshot of everything active , so printer, model, any modifiers etc that may be in play. Without its all just guesswork.
Profile
I cant share project stl file.
I dont think thats profile problem.. its prusaslicer itself failing.
How can you explain that same profile somtimes make good sometimes not..
FIXED
Added option :
G92 E0
