Parts of model cut out during slicing
Andrew R
(@andrew-r)
Respondido : 26/07/2021 1:05 pm
Lichtjaeger
(@lichtjaeger)
Bad model
I would assume that the model has problems with the face orientation. You would have to check and fix this with an editor like Blender or Fusion360.
Respondido : 26/07/2021 1:55 pm
Possible STL problems, upload zipped 3MF project file
Save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations. This sort of problem is usually related to faults in the STL that make slicing difficult. You might try running a repair on the STL.
Respondido : 26/07/2021 1:59 pm
1 les gusta
Andrew R
(@andrew-r)
3MF file
Groose file
I'm not really sure if this will work i'm quite new to 3d printing and using the forums.
Respondido : 26/07/2021 4:21 pm
Be sure to zip & attach
Posted by: @andrewkoubler
Groose file
Be sure to zip the file. Use the Attach file button right below the edit area.
Respondido : 26/07/2021 4:33 pm
jsw
 jsw
(@jsw)
title here
My PS is not liking that .3mf file.  It looks to me like it's a 'runt', missing most of the model information.
Respondido : 26/07/2021 4:34 pm
RE: Ah there it is!
Good grief, the new forum "improvements" make it so attachments and links don't stand out at all.
I'm also getting a "model failed" error.
Respondido : 26/07/2021 4:37 pm
