Parts coming away from the bed
BrettG
(@brettg)
So having issues with parts coming away from the bed on the sides.
think maybe the environment I'm printing in might be the issue, in a outbuilding/gym that's around 8c here in the UK.
note : I have to warm the machine up with a fan heater to remove the min error temp before I'm able to use the preheat function.
Printing in PLA using the default settings, calibrated Z level with 75x75 square.
Best Answer by Diem:
PLA doesn't usually need an enclosure. You can improvise a temporary one to test whether it helps by putting a large cardboard box over the printer.  It is more likely to be caused by drafts than ambient temperature so a simple screen, or just being careful to shut doors/windows might be enough.
Veröffentlicht : 23/11/2021 8:57 am
BrettG
(@brettg)
RE: Parts coming away from the bed
forgot to mention, the bed is cleaned with the soap and water technique.
I was doing some tests so had 4 of these each in one corner of a mk3s bed so maybe because its moving between layers to each part the cold environment is causing issues because if I print just one part and the printer is concentrating on this then I don't get the issue,
Veröffentlicht : 23/11/2021 9:08 am
Veröffentlicht : 23/11/2021 11:31 am
BrettG
(@brettg)
Posted by: @diem
I think you're right about the enclosure, currently its in one but with the door open due to being PLA, I guess with the dramatic drop in  temperatures I need to account for this and close the door and try to keep a higher ambient temperature.
Thanks for taking the time to respond to my issue.
Veröffentlicht : 23/11/2021 11:48 am
BrettG
(@brettg)
update: controlled the enclosure by closing the door and increased the ambient temperature seems to have solved the issue, thanks for the help
Veröffentlicht : 24/11/2021 11:50 am
Also your other post saying you have under extrusion, well it looks like your z could do with coming down a touch.  That will also greatly effect how well parts stick to the bed.
Fix 2 things with one adjustment.
Veröffentlicht : 24/11/2021 12:17 pm
BrettG
(@brettg)
Posted by: @neophyl
thanks for the response, yes I will have take your advice and go down this route then and adjust slightly more on the Z
Veröffentlicht : 24/11/2021 12:19 pm
