Paint on fuzzy skin in brush mode wraps corner of object to non-visible side. V2.9.2
PublicUsername
(@publicusername)
So I am having a problem with the brush mode for fuzzy skin. I am running 2.9.2 on Mint 22.1, and while the smart fill works as expected, the brush seems to wrap to sides that are not visible. Not sure if this is a known issue or expected behaviour.
Paint on at applied angle with red circle to show where applied
Viewed at angle to show wrapping
P.S. Is it just my OS or is there not meant to be a file selection tool when attaching an image? I had to type in the full path.
File selection
Best Answer by BaconFase:
Change from the sphere brush to the circle brush if you don't want a 3 dimensional application of the tool.
Opublikowany : 05/07/2025 2:10 am
PublicUsername
(@publicusername)
RE: Paint on fuzzy skin in brush mode wraps corner of object to non-visible side. V2.9.2
Anyone have a link to instructions on how to upload images in a forum post, it seems to have not worked?
Opublikowany : 05/07/2025 8:29 am
I place my cursor where I want the image to appear, then open a filemanager window in a small window,   and drag the image file that I want to insert, into the bottom of the main text insertion window, when the image gets to a good position relative to the insertion box, the insertyion box changes colour, and I Drop the file into the insertion text box
Opublikowany : 05/07/2025 9:08 am
PublicUsername
(@publicusername)
Thanks for the tip.
This shows the angle of selection.
Opublikowany : 05/07/2025 9:34 am
PublicUsername
(@publicusername)
It did not seem to let me put in two images in the one post, even though I have seen it on other posts. The whole image insertion seems a little clunky.
This shows the selection on the other side which I would have thought should not be there.
Opublikowany : 05/07/2025 9:36 am
BaconFase
(@baconfase)
Opublikowany : 05/07/2025 10:08 pm
1 ludzie polubili
PublicUsername
(@publicusername)
Ha, ha, haaa. Another PEBKAC error. Thx.
Opublikowany : 05/07/2025 10:46 pm
ssmith
(@ssmith)
Also look at the 'triangles' brush for narrow faces like the one in the picture.
Opublikowany : 06/07/2025 4:42 pm
