Paint on fuzzy skin in brush mode wraps corner of object to non-visible side. V2.9.2
So I am having a problem with the brush mode for fuzzy skin. I am running 2.9.2 on Mint 22.1, and while the smart fill works as expected, the brush seems to wrap to sides that are not visible. Not sure if this is a known issue or expected behaviour.
P.S. Is it just my OS or is there not meant to be a file selection tool when attaching an image? I had to type in the full path.
Best Answer by BaconFase:
Change from the sphere brush to the circle brush if you don't want a 3 dimensional application of the tool.
RE: Paint on fuzzy skin in brush mode wraps corner of object to non-visible side. V2.9.2
Anyone have a link to instructions on how to upload images in a forum post, it seems to have not worked?
I place my cursor where I want the image to appear, then open a filemanager window in a small window, and drag the image file that I want to insert, into the bottom of the main text insertion window, when the image gets to a good position relative to the insertion box, the insertyion box changes colour, and I Drop the file into the insertion text box
It did not seem to let me put in two images in the one post, even though I have seen it on other posts. The whole image insertion seems a little clunky.
This shows the selection on the other side which I would have thought should not be there.
Ha, ha, haaa. Another PEBKAC error. Thx.
Also look at the 'triangles' brush for narrow faces like the one in the picture.
