Organic supports are outside the build plate
Paul Cobbaut
(@paul-cobbaut)
Is there any way to tell Prusa Slicer to put these supports on the build plate? There is room enough...
-- Sent from Debian
Opublikowany : 27/03/2023 12:02 pm
RE: Organic supports are outside the build plate
could you please attach the .3mf file (Zip Compressed)?
Opublikowany : 27/03/2023 12:08 pm
1 ludzie polubili
Paul Cobbaut
(@paul-cobbaut)
Attached (I hope).
-- Sent from Debian
Opublikowany : 27/03/2023 12:10 pm
you need to save the file, zip compress the file and attach it to the post...
Opublikowany : 27/03/2023 12:17 pm
Paul Cobbaut
(@paul-cobbaut)
tribune
-- Sent from Debian
Opublikowany : 27/03/2023 12:21 pm
Paul Cobbaut
(@paul-cobbaut)
Thanks for the quick response. Hope the  upload now works.
-- Sent from Debian
Opublikowany : 27/03/2023 12:22 pm
I was unable to get organic supports to work.
have you tried 'Snug' supports?
Joan
Opublikowany : 29/03/2023 1:28 pm
Paul Cobbaut
(@paul-cobbaut)
I only tried other supports in the slicer, until now I just print the top beams separately and glue them. Can this be reported as a bug in PrusaSlicer?
-- Sent from Debian
Opublikowany : 29/03/2023 1:40 pm
Yes,
You can raise it as an issue on Prusa Slicer Github!
Opublikowany : 29/03/2023 1:49 pm
Paul Cobbaut
(@paul-cobbaut)
Done and thanks.
https://github.com/prusa3d/PrusaSlicer/issues/10184
-- Sent from Debian
Opublikowany : 29/03/2023 2:01 pm
Thank you!
Regards Joan
Opublikowany : 29/03/2023 2:12 pm
