Organic supports are outside the build plate
Is there any way to tell Prusa Slicer to put these supports on the build plate? There is room enough...
-- Sent from Debian
RE: Organic supports are outside the build plate
could you please attach the .3mf file (Zip Compressed)?
Attached (I hope).
-- Sent from Debian
you need to save the file, zip compress the file and attach it to the post...
-- Sent from Debian
Thanks for the quick response. Hope the upload now works.
-- Sent from Debian
I was unable to get organic supports to work.
have you tried 'Snug' supports?
Joan
I only tried other supports in the slicer, until now I just print the top beams separately and glue them. Can this be reported as a bug in PrusaSlicer?
-- Sent from Debian
Yes,
You can raise it as an issue on Prusa Slicer Github!
Done and thanks.
https://github.com/prusa3d/PrusaSlicer/issues/10184
-- Sent from Debian
Thank you!
Regards Joan
