One perimeter objects isues
Hi, I am testing a single perimeter object printing. There are two problems which I can not solve by slicing setup. One is adding material to the outer corners, which makes cornes rather ugly, than good looking.
Second one is joining perimeters (it is not a spiral vase case), at the start of the perimeter is a huge gap - more in a picture.
I tried many printing setup, without success. Any sugestion? Thanks
RE: One perimeter objects isues
Save your slicer setup as a project. Then zip the project file. And attach the zipfile. And we can look at your settings and make suggestions
Regards Joan
Thank you!
@vojta-3
This is not a slicer setup as a project. This is just a .stl file.
The request was for a Slicer project, a .3mf project file exported fro slicer, setup as you were trying to slice it, so we could see what you were doing wrong, and explain how to fix it.
I am sorry, confused with my own files. This is the right file 3rmf.
And project after slicing the object if it is needed.
Thank you!
Only the 3mf project file saved in Slicer and zipped is needed. If you save it before or after slicing does not change anything....
OP might have meant the gcode file with "after slicing". No , please no gcode file
