Odd slicing behaviour using multi material painting
I'm trying to slice an object using just two colours. The first one will cover only almost the whole surface of the first layers except the borders. The second one will cover the rest of the object.
My problem is the slicer result is show a rectangle of the second color where it shouldn't. I assume top layers color are somehow invading the first one.
Is there any setting I can tweak to prevent this weird behaviour? I attach below the clip where I show my issue.
Thanks in advance!
Publié : 14/05/2024 12:07 pm
