null character error
ccole
(@ccole)
hello everyone I ran into the problem of my PrusaSlicer.ini having null characters which will not let me load the slicer. I have deleted the file, deleted the whole program and reinstalled it but nothing has worked can I get some tips on how to fix this. I am on windows 10.
thank you for your time
Best Answer by Neophyl:
Uninstalling the software does NOT remove any settings.  If there is a problem with the settings stored then those will all have to be nuked too. Usually in Users>user account>AppData>Roaming>PrusaSlicer on a standard win install.
Once completely cleared out you should at least be able to re-install and go through the setup wizard again.
You did make backups of your custom profiles regularly using the Export Config Bundle option in slicer didn't you ?  Thats the 'proper' way of backing up anything custom.  They should be in that folder too so it might be best to make a backup before deleting, at least of the filament, printer and print folders.
Opublikowany : 28/12/2022 10:15 pm
1 ludzie polubili
RE: null character error
Opublikowany : 28/12/2022 11:52 pm
2 ludzie polubili
ccole
(@ccole)
Thank you very much it worked
and I have never backed up customs before but I am only a year in and am still trying to figure things out so I didn't have many; but thank you for the good practice.
Opublikowany : 29/12/2022 2:55 am
jopal34
(@jopal34)
This worked great for me too! Thank you for the help!
Opublikowany : 13/06/2023 7:31 pm
