Nozzle Parks in Different Spot
Zeelily Clockwerks
(@zeelily-clockwerks)
greetings ever since upgrading to 2.42, When a print is finished, the nozzle parks with the z axis at zero. Before it would got to around 150. Did the default gcode change this in the new version?
Veröffentlicht : 07/07/2022 2:02 pm
RE: Nozzle Parks in Different Spot
You don’t mention your printer. If it’s a mini then you need to update the printer firmware. There’s a known issue with the older mini firmware and new PS versions.
If it’s not the mini then you will need to post a zipped up 3mf project file here so that the configuration can be checked.
Veröffentlicht : 07/07/2022 7:22 pm
