not able to slice
widget2k13
(@widget2k13)
not able to slice
hi, i am trying to slice 3 small files on slicer and everytime no matter what i try it doesnt work, it leaves holes and missing parts all over, is htere a way to get around this does anyone know please ?
Veröffentlicht : 30/08/2020 7:11 pm
RE: not able to slice
Your models are probably damaged. Please either post the models or a saved project containing them. You will need to zip them up for the forum to accept them.
If you are on windows 10 you can try right clicking and use the fix through netfabb option which may be able to automatically repair.
Veröffentlicht : 30/08/2020 7:19 pm
widget2k13
(@widget2k13)
i did try a repair in prusa slicer but it never helped, im on a mac , i have added the files if you dont mind taking a look please
Attachment removed
Veröffentlicht : 30/08/2020 7:26 pm
Ok, there is nothing wrong with the models, although pumpkin 3 has to be trimmed on the bottom (by roughly 0.2mm) to get a flat surface to get it nicely on the bed and no generate a missing layers error.
The issue is that the walls are too thin for a standard 0.4mm nozzle (with the default 0.45 width) to pick up.  Even with a xy compensation of 0.2 (which makes every part of the model 0.2mm thicker it still doesn't pick up all the details.  Also there are lots of overhangs on pumpkins 2 & 3 so they wont print well and I assume you don't want support inside as that will be difficult to impossible to remove.
Its not until you scale them up to 150% AND use at least 0.1 xy compensation that they start to pick up all the details and even then the overhang issue remains.  No matter how they are scaled that wont change.  Basically 2 & 3 are not designed to be 3d print friendly.
Veröffentlicht : 30/08/2020 8:08 pm
widget2k13
(@widget2k13)
@neophyl
thank you, im not sure whats happened as i seen the print of them on thingiverse from an mmu2 , i printed all the other parts no problem. im just stuck on these 3 , i would of thought if an mmu2 could print them then a single nozzle should ?
Veröffentlicht : 30/08/2020 8:31 pm
widget2k13
(@widget2k13)
oh and ive tried slicing them on my mini with .25 nozzle and still no joy with that neither 🙁
Veröffentlicht : 30/08/2020 8:32 pm
Well what settings has the creator on his thingiverse item used ?  Usually they mention print settings or it gets asked in the comments if you read them  Unfortunately thingiverse is returning zero objects when I search for pumpkin at the moment, its being particularly terrible this evening so I havent been able to look myself.
Veröffentlicht : 30/08/2020 8:56 pm
widget2k13
(@widget2k13)
https://www.thingiverse.com/thing:3910831
dont know if its much help
Veröffentlicht : 30/08/2020 9:25 pm
Thanks.  The author says he scaled it to 125% and if you look at the first picture you can see pumpkin3 is missing the details in the eyes, so I wouldnt say his print is complete either.  Its not a hi resolution pic either so Id say that he also has had issues and that it looks ok from a distance.
Veröffentlicht : 30/08/2020 9:38 pm
widget2k13
(@widget2k13)
so its a no go then 🙁 printed all the other parts as well haha
Veröffentlicht : 30/08/2020 9:45 pm
Well you could just see what different values of xy compensation gives you.  try values above 0.2mm  Also it seems to slice better with detect thin walls turned off if you use xy compensation.  The parts arent big so its not alot of filament to play with.  Even if the tops are a bit droppy due to the internal overhangs you probably wont notice on those shapes and at that size.
Veröffentlicht : 30/08/2020 9:50 pm
widget2k13
(@widget2k13)
ok i will try see what happens , thank you
Veröffentlicht : 30/08/2020 9:55 pm
