Normal menu in latest PrusaSlicer
СС
 СС
(@-40)
Utenti
After the (probaly) last update to v.2.8.0, some new menu was introduced in PrusaSlicer.
Is there some setting to make the program work with a normal menu, like it did before?
Questa discussione è stata modificata 2 years fa da СС
Postato : 11/07/2024 8:31 am
1 persone hanno apprezzato
RE: Normal menu in latest PrusaSlicer
Simple answer is no.  Not at the moment.  This has been complained about on here several times already and there are multiple issues about getting the old UI back or at least an option to do so on the Prusa Slicer github page.  https://github.com/prusa3d/PrusaSlicer/issues/12943   go add your support to that.
Postato : 11/07/2024 9:37 am
It  gets worse - I've slowly been moving everything over to Raspberry Pi's but there is no ARM build of 2.8.0 -  the previous 2.7.4 build only worked on the command line so I was hoping for improvement whilst using older versions - then the new 2.8.0 comes along and is a pain to use on the old X64 Linux machine(s) that I'm trying to retire...  So 2.7.4 lives on.
Postato : 11/07/2024 11:03 am
СС
 СС
(@-40)
Utenti
Thanks, I did.
Posted by: @neophyl
... https://github.com/prusa3d/PrusaSlicer/issues/12943   go add your support to that.
Postato : 11/07/2024 11:17 am
