No Icons
RPD653
(@rpd653)
No Icons
I just downloaded PrusaSlicer 2.3.0 and when application opens, there are no icons or gridlines on the plate. The location of the icons are just dark gray squares. The plate is just black with the colored axis arrows in the corner. You can still click on the area where the icon should be and the function works, but there is no visual of the icon. Also, if you move the mouse over the area of the icons, the icon description pops up but it is a white illegible blob. I am running Windows 10 Pro 64 bit on an HP Prodesk PC. Unistalled and re-installed with the same problem.
Anyone have any ideas?
Respondido : 21/05/2020 1:30 pm
RE: No Icons
Have you selected a Prusa printer profile? Go through the Configuration->Configuration Assistant wizard and be sure to select a supported printer model. If you are using a different printer, specify which as it takes more steps to get the pretty bed display.
Respondido : 21/05/2020 2:49 pm
RPD653
(@rpd653)
RE: No Icons
@bobstro
Yes. I have the Prusa i3 MK3S profile configured. Went through the configuration wizard again just to make sure. No change to the issue.
Respondido : 21/05/2020 3:07 pm
