Need help with cylinder
Chip
 Chip
(@chip-4)
Hi all,
I was wondering if someone can help me.  I need to create an open cylinder with the following dimensions:
OD: 52mm.  ID: 43mm.  Height: 20mm
I can create an open cylinder but I cannot figure out how to do the OD ID part.
Thank you for any help you can give me.
Chip
Opublikowany : 25/04/2022 1:14 pm
John Doe
(@john-doe-20)
RE: Need help with cylinder
I think you would create a "negative" space using the cylinder and position it within the larger cylinder. You can use the "part manipulation" controls in the bottom left to fine-tune the positioning and size of the two cylinders.
Opublikowany : 25/04/2022 1:32 pm
Chip
 Chip
(@chip-4)
But how would I fill in the space between the two cylinders?
Opublikowany : 25/04/2022 1:40 pm
John Doe
(@john-doe-20)
The first cylinder should be "solid" and the second hollows out the middle. Is that not what you want? Or is that not what you are seeing?
Opublikowany : 25/04/2022 2:51 pm
What @twbaum said.
Alternatively, try tinkercad.com. For something as simple as that, it sure beats any more powerful CAD software. Just create a cylinder, create a small "hole" cylinder and align them on the three axis with the L shortcut. Literally a 1 minute job.
Opublikowany : 25/04/2022 3:11 pm
Chip
 Chip
(@chip-4)
Thank you very much!  I will go try that now and come back if I need more help.  Thank you again.
Opublikowany : 25/04/2022 3:21 pm
Chip
 Chip
(@chip-4)
Yes, that is what I want.  Thank you.
Opublikowany : 25/04/2022 3:23 pm
JustMe3D
(@justme3d)
And the bottom being what thickness? Or open at both ends?
Opublikowany : 25/04/2022 3:29 pm
Chip
 Chip
(@chip-4)
What do you mean the "L" tool?  Thank you.
Opublikowany : 25/04/2022 3:32 pm
Chip
 Chip
(@chip-4)
I am trying to make a cylinder, open both ends, 52mm x 52mm x 20mm, with a wall thickness of 9mm.  Thank you.
Posted by: @justme3d
Opublikowany : 25/04/2022 3:33 pm
Robin
(@robin)
If you want to do it in slicer only:
See attached file... Shape-Cylinder.3mf
You can use the z position of "Generic-Cylinder" to change the bottom thickness. Its 5 mm right now and the position is set relative to the "shape-cylinder".
Opublikowany : 25/04/2022 3:35 pm
