Multiple versions of PrusaSlicer at the same time
mhejjas
(@mhejjas)
Is it possible to run different versions of PrusaSlicer on the same OS?
So I can try v2.6.0, but if something goes wrong, I'll still have the 2.5.0 version to do the work.
thanks
Best Answer by JoanTabb:
Yes, the Prusa Slicer 2.6.0 Alpha2 image, is in a different directory
I loaded the alpha yesterday, and I can still access 2.5.0
Postato : 01/02/2023 10:00 am
RE: Multiple versions of PrusaSlicer at the same time
Postato : 01/02/2023 10:29 am
mhejjas hanno apprezzato
mhejjas
(@mhejjas)
It was fast, thanks a lot 🙂
Postato : 01/02/2023 10:34 am
response times vary dependent upon volunteer's / moderators time availability,
Most moderators are volunteers
Postato : 01/02/2023 10:56 am
Prusa Slicer uses 3 different default locations for the configuration profiles, alpha, beta and release.  Precisely so you can try out and test new versions.
There are also ways of running multiple versions within a category too by using switches on the start commands to explicitly tell the software where to use for its configuration data.
Postato : 01/02/2023 11:39 am
