Multimaterial painting with more than two colours?
klaus.g2
(@klaus-g2)
Hallo,
is there a way to use more than two colours? I would need three.
many thanks
Klaus
Napsal : 14/11/2024 1:38 pm
RE: Multimaterial painting with more than two colours?
with MMU2 and MMU3 you can use 5 colours
Joan
Napsal : 14/11/2024 1:39 pm
Robin
(@robin)
Fun fact: with the MMU you can also change filaments mid-print and therefore use more than 5...
@klaus-g2 which printer and which project (post a ZIPed project file from slicer), besides that: the answer to your question is: yes.
Napsal : 17/11/2024 5:15 pm
klaus.g2
(@klaus-g2)
Sorry, but that's all I didn't ask for. I know that I can use 5 colors in the MMU.
And I know why I asked precisely in the Forum "PrusaSlicer" and why I asked for the funktion "Mulitmaterial painting".
The question is how I can choose more than two colors with this funktion.
regards Klaus
Napsal : 19/11/2024 3:58 pm
Walter Layher
(@walter-layher)
After you are finished painting with the first two colors, select the dropdown for first or second color and choose Extruder 3 (if you have 3 extruders setup). Then you use your left or right mouse button to paint the third color. When I just tried it in PrusaSlicer it showed the correct colors in the preview at least. I have not tried printing with this setup yet.
Napsal : 19/11/2024 4:09 pm
klaus.g2
(@klaus-g2)
Hallo Walter,
this operation mode seems to work (I expected several dropdown lines for each extruder).
many thanks
Klaus
Napsal : 19/11/2024 4:32 pm
1 lidem se líbí
