Multimaterial painting with layers
Kodo Kil
(@kodo-kil)
Miembro
Hi !
As you know there are often multicolor objects designed to be printed without a mmu where you just change the color after a specific layer.
How do you print something like this on a multicolor printer ? I know you can right click on the layer and "add color change", but that wont generate a waste tower and initiate tool change (or should it ? It does not for me)
You can use multimaterial painting to paint it, but it is a lot of work to paint a whole lettering for example.
Is there any way to use multimaterial painting to paint everything over some layer ?
Or how do you handle this ?
Respondido : 15/05/2024 9:32 am
RE: Multimaterial painting with layers
I don't know about printers with an MMU but if you have an XL, just right click on the color change position in the preview, and you'll get an option to switch code to Change extruder.
Respondido : 15/05/2024 11:05 am
AnsleyRempel
(@ansleyrempel)
Miembro
Right click and select Add color change so the printer pauses there and you can change the filament manually. This will be a very economical way because it does not create a waste tower and does not need to change the printing tool, because it only uses one extruder.
Geometry Dash Lite
Respondido : 04/04/2025 6:40 am
