Multi material support #feature request
Matze Jo
(@matze-jo)
  • Is it possible to create supports out of two materials? PVA Filament is suprisingly expensive and i would like to use it only on contact points to the surface of my part.
Best Answer by Neophyl:
Yes.  Under Print Settings>Multiple Extruders>Extruders you can assign which extruder is used for various features.  There are both Support Material and Support Material Interface option there.   Its a Yellow setting so you must be in Advanced mode to see them.
Posted : 04/03/2023 8:00 am
RE: Multi material support #feature request
Posted : 04/03/2023 8:27 am
Matze Jo liked
Matze Jo
(@matze-jo)
🤯wow. Thanks for your help. I will try this. Is there also something similar for infill? Expensive outer wall material and cheap infill material?
Posted : 04/03/2023 9:32 am
With the Multimaterial unit you can even define different filament for infil and perimeters on a feature
on this setup, the outline for the letters is set to black, whilst the infill is white,    which makes the letters 'Pop'
Posted : 04/03/2023 11:02 am
Matze Jo liked
