monotonic vs. Monotonic lines - top v bottom?
Phantastic Plastic
(@phantastic-plastic)
It sounds like monotonic lines fill is an improvement over standard Monotonic.  Why does bottom fill default to monotonic and top to monotonic lines?
Publié : 04/09/2023 12:41 pm
RE: monotonic vs. Monotonic lines - top v bottom?
You would have to ask the Dev's over on  the Prusa Slicer github for their reasoning.
If I had to guess though I would say because its not needed on the bottom with a Prusa printer.  The squish you get when the first layer is properly set makes the lines option pointless.  The extra time taken to print the Monotonic Lines would be a waste.  For example -
Can you see any gaps in that ?  All that's there is the surface texture/damage from an old 3+ years smooth print sheet.
Publié : 04/09/2023 1:17 pm
