monotonic vs. Monotonic lines - top v bottom?
It sounds like monotonic lines fill is an improvement over standard Monotonic. Why does bottom fill default to monotonic and top to monotonic lines?
Respondido : 04/09/2023 12:41 pm
RE: monotonic vs. Monotonic lines - top v bottom?
You would have to ask the Dev's over on the Prusa Slicer github for their reasoning.
If I had to guess though I would say because its not needed on the bottom with a Prusa printer. The squish you get when the first layer is properly set makes the lines option pointless. The extra time taken to print the Monotonic Lines would be a waste. For example -
Can you see any gaps in that ? All that's there is the surface texture/damage from an old 3+ years smooth print sheet.
Respondido : 04/09/2023 1:17 pm
