Modifier, enforcer, blocker? What does each do? Tutorial?
What is the difference between adding a modifier, enforcer or blocker. Is there a tutorial for PrusaSlicer or help file?
Thanks in advance
Respondido : 12/05/2020 1:29 am
RE: Modifier, enforcer, blocker? What does each do? Tutorial?
Documentation is in development. In short:
- A modifier lets you change print parameters for any areas covered by the modifier part. Things like infill density or other print settings.
- Support blockers prevent support in the area covered by the part. Good if you want support in all but a few select areas.
- Support enforcers are the opposite, forcing support in the area covered by the part. Good if you only need support in a specific care.
Respondido : 12/05/2020 4:28 am
