Missing tools on left hand menu
rogerinhawaii
(@rogerinhawaii)
I'm running PursaSlicer 2.7.1 and suddenly the left-hand menu of options has fewer options. In particular I want to cut the object but the cut option just isn't there. See the attached image. It's also missing the paint and seam options.
I CAN bring up and use the Cut dialog by pressing 'C' on the keyboard, but even that only works some of the time. It seems to work for really simple, small objects, like just a box, but not for larger, even moderately larger objects, in which cases hitting 'C' does nothing, no Cut dialog appears.
Publié : 25/01/2024 1:44 am
mixer3d
(@mixer3d)
RE: Missing tools on left hand menu
Hi @rogerinhawaii change the settings of slicer to Advanced or Expert from the Simple mode you have now.
Publié : 25/01/2024 12:33 pm
rogerinhawaii
(@rogerinhawaii)
Thank you, thank you, thank you!
I've been using PrusaSlicer for years now, and originally set it for Expert mode, never giving it a second thought.
Apparently, somehow (a recent auto update??), it got reset so it was no longer on the Expert setting.
It's now back to working properly. thanks to you!
Publié : 25/01/2024 5:49 pm
mixer3d a aimé
