Maybe a first layer flow problem?
Pasubio
(@pasubio)
Hi all,
in the attached image you can see a 0.25 mm height first layer, printed in PET-G with a 0.4 mm nozzle (o.5 mm extrusion width), 18 mm/s speed, using PS 2.6.1
Recently I observed an uneven first layer deposition: the layer appear so good in some area of the print (green dot) and not so good on other parts (red dot.)
We all know that PET-G is tricky: it stick to the nozzle and do not love to be squished to much on the bed, at the opposite printing a tick first layer lead to a weak adhesion.
Have you ever addressed this kind of uneven first layer deposition?
Thank you!
Napsal : 25/10/2023 11:06 am
Extrudinaire
(@extrudinaire)
RE: Maybe a first layer flow problem?
Find a solution?
Napsal : 14/12/2023 7:19 pm
