Material change mid-print
ByteSlinger
(@byteslinger)
I've recently transitioned from Simplify3D to PrusaSlicer which on the whole I much prefer.
However, I'm looking to print something at the moment and mid-print (at a specific layer) I need to change from PLA to a flexible material.
This means not only do I need to initiate a filament change at that layer but need to apply different print settings after the change.
Is this something that's possible with PrusaSlicer or will I have to still use Simplify3D for that?
Thanks
Best Answer by Robin:
You can use modifiers to apply different settings pretty much everywhere you want.
https://help.prusa3d.com/en/article/modifiers_1767
Postato : 27/01/2021 2:52 pm
Robin
(@robin)
RE: Material change mid-print
Postato : 27/01/2021 5:26 pm
1 persone hanno apprezzato
ByteSlinger
(@byteslinger)
@robin
Exactly what I was after, thanks
Postato : 27/01/2021 5:33 pm
Vitom
(@vitom)
The modifier only allows you to apply one parameter at a time. If one wants to switch between flexible and e.g. PETG, that's not very practical because there are several parameters involved and you'd have to copy all of them manually. Is there a way to achieve that?
Postato : 12/10/2021 7:00 am
Sp4rkR4t
(@sp4rkr4t)
Unfortunately I don't think so, an ability to use height modifiers to change filament profile would be an extremely powerful tool.
Postato : 17/12/2021 12:11 pm
spark
(@spark)
Late to the party but was looking for help before hacking code.  Looks like that might be only option.  Plan is to slice two materials with color swap in same places.  Then compare G-code slicing where appropriate, initiating extruder temperature change while or just before swap (keeping 1st layer material heatbed temp same).  Why this isn’t part of Advanced features layer filament change beyond me, most polymers will stick  to themselves.  Wish me luck!
MK2S kit owner since 8/15/2017
Postato : 09/01/2024 4:09 pm
ADVmachines
(@advmachines)
Utenti
I am curious if you managed to figure this out for your print needs. I have been contemplating trying to find a way to do this as well. I have Simplify3D v5, but I currently much prefer PrusaSlicer (2.9.x Alpha) for what I am doing. What I want to do is change from Lightweight PLA to a different filament for ~2 layers then change back to the LW PLA. I think that I am going to mess with printing perimeters outside in (normally prints inside to outside)... and at the point where the outer perimeter has completed and is about to shift in one, that is when the filament gets changed... heats to new extruder nozzle temp... does the 2 layers of work, then changes back to the LW PLA... proceeds with print... rinse+repeat. I know I can do some of this in 'layers' (I am doing this presently with infill and perimeter count changes earlier in the print), but I think that it will require some GCODE hacking to get what I just described to happen... I have not found it as a function in the UI
Postato : 14/12/2024 6:21 pm
