Making user customizations to the ini sticky
TickTock
(@ticktock)
Decided to modify the "output_filename_format" in the ini file so I could avoid a lot of typing each time I export gcode.  However, I cannot seem to make it work.
I have edited every entry in:
...\Prusa3D\PrusaSlicer\resources\profiles\PrusaResearch.ini
but it still tries to save using the original (very long) filename. I also tried exporting a config bundle, editing it, and importing.  Same result.  If I export a new config bundle after importing my edited version, the new config bundle does reflect my changes.  However PrusaSlicer seems to be ignoring all "output_filename_format" entries.  Suggestions?
On version 2.1.0
Publié : 22/09/2019 5:59 pm
RE: Making user customizations to the ini sticky
Just save copies of the defaults with the setting overrides you desire. Make your change, hit the save icon and give it a new name. I put a date stamp on my configuration changes.
Publié : 22/09/2019 7:37 pm
TickTock
(@ticktock)
That works - just tedious to do for all profiles and then I end up with a bunch I will never use.  Was hoping for a way to modify things outside the tool so I could use search-replace to apply to all profiles.  I suppose if the user presets appeared above the system presets so I didn't have to scroll to them that would help.  As I type this I realize it sounds really nit-picky.  Really, I'm not that bothered by it - was just wondering why my attempts to modify the system presets failed and if anyone worked out how to do it.
Publié : 22/09/2019 8:29 pm
Posted by: @ticktock
[...] Was hoping for a way to modify things outside the tool so I could use search-replace to apply to all profiles.
You can create your own config bundles. I make use of the inherits = feature to minimize duplication of effort. Any profile will inherit any settings specified under the profile listed by name in an inherits = line. You can use this to create sub-profiles that only marginally differ from the parent. I've got a (rough) example here. If you import this as a config bundle, you'll end up with a bunch of profiles. Unfortunately, if you then export your settings as a config bundle, each profile is complete, meaning you'll need to maintain your "master" bundle with the inherited sub-profiles separately. It's a little annoying, but it saves me a lot of work, especially with printer profiles where I want common gcode across all my profiles.
You could probably hide them through clever use of the dependencies. I use this to hide unusable layer heights in print profiles based on the nozzle size I've selected in the printer profile.
Publié : 23/09/2019 3:29 am
TickTock
(@ticktock)
@bobstro
Cool.  Lots of good stuff here - thanks!
Publié : 23/09/2019 11:27 am
