Makerbot Replicator + Compatibility
Is the slicer compatible with Replicator + or can it output ".Makerbot" files
I got it working with a replicator 2 so first setup your profile bassicly just go custom profile and it talks you through it if your on windows download this https://github.com/markwal/GPX/releases and unzop file then run exe file if your on Linux download the gz file into a folder and make a terminal into it then enter sudo apt-get install gpx once you do that and it installs once you get a gcode file put it through that converter and it will export a file should be able to print on it
This is what I do for my replicator2 it works with all replicator
RE: Makerbot Replicator + Compatibility
If you run into problems let me know
Looks like the "Replicator +" can only read .makerbot files. Where as the replicator 2 and 2x can read the x3G files. Does anyone know of anyway to convert from the prusa slicer into ".makerbot"?
Oh sorry thought all replicator ran on x3g file turns out its only ones before 5 gen
I actually had the same question and found this post processor script on github and have done some updating/merging to it between different forks so you can now set it up as a post processing script in Prusaslicer and it will fully make the .makerbot file for you. I haven't extensively tested it, and I haven't actually setup any prusaslicer profiles yet, made the ones I needed on orcaslicer, but I thought you might want to know about it.
https://github.com/charely6/mbotmake
