Makerbot Replicator + Compatibility
Bryan Sonnier
(@bryan-sonnier)
Mitglied
Is the slicer compatible with Replicator + or can it output ".Makerbot" files
Veröffentlicht : 13/09/2023 3:11 pm
Hello
(@hello)
I got it working with a replicator 2 so first setup your profile bassicly just go custom profile and it talks you through it if your on windows download this https://github.com/markwal/GPX/releases and unzop file then run exe file if your on Linux download the gz file into a folder and make a terminal into it then enter sudo apt-get install gpx once you do that and it installs once you get a gcode file put it through that converter and it will export a file should be able to print on it
This is what I do for my replicator2 it works with all replicator
Posted by: @bryan-sonnier
Veröffentlicht : 13/09/2023 7:14 pm
Hello
(@hello)
RE: Makerbot Replicator + Compatibility
If you run into problems let me know
Veröffentlicht : 13/09/2023 7:17 pm
Bryan Sonnier
(@bryan-sonnier)
Mitglied
Looks like the "Replicator +" can only read .makerbot files.  Where as the replicator 2 and 2x can read the x3G files.  Does anyone know of anyway to convert from the prusa slicer into ".makerbot"?
Veröffentlicht : 13/09/2023 8:52 pm
Hello
(@hello)
Oh sorry thought all replicator ran on x3g file turns out its only ones before 5 gen
Veröffentlicht : 14/09/2023 12:48 am
Charely6
(@charely6)
I actually had the same question and found this post processor script on github and have done some updating/merging to it between different forks so you can now set it up as a post processing script in Prusaslicer and it will fully make the .makerbot file for you. I haven't extensively tested it, and I haven't actually setup any prusaslicer profiles yet, made the ones I needed on orcaslicer, but I thought you might want to know about it.
https://github.com/charely6/mbotmake
Veröffentlicht : 27/06/2024 6:35 pm
