Maintaining MMU Filaments with multiple Prusa/Delta printers
I am running an Mk3S with MMU2 as well as a Delta K280 with PrusaSlicer. When I shift to the Delta printer in PrusaSlicer to slice something and then shift back to the Prusa Mk3S MMU2 all of my filaments are gone, replaced by whatever filament I was using on the single-effector Delta.
Is there any way to have PrusaSlicer remember the filament(s) that are loaded in each printer while switching between them? Thank you!
RE: Maintaining MMU Filaments with multiple Prusa/Delta printers
If you save your last Prusa Project as a project file using the 'File' menu, you can go do the other printer, and when you want to come back to the Prusa setup, you can re load the prusa project file.
If you also save the last Delta Project, you can toggle between the projects by reloading the latest project from which ever printer you want to use next
Joan, I will give that a try! Thank you!
