Longer print times than in cura
[Rozwiązany] Longer print times than in cura
otto_b
(@otto_b)
Hello there,
i just switched to Prusaslicer and wanted to generate the gcode for a benchy with it. I have a 0,6 nozzle profile in cura which works really good and have an estimated print time of 40 minutes in Cura. Now i took a while and copied all the settings (at least i thought) to prusaslicer. I get an approximated print time of 1h and 10 minutes. Thats almost double the print time in cura.. I already found some post about the cooling setting that can reduce the print speed, but changing this didnt really help. Its the perimeters that take double the time than in cura.
I will attach my prusa project and my cura project. Maybe someone experienced could have a quick look. That would really help me!
Thanks in advance:)Benchy in Prusa and Cura
Opublikowany : 28/02/2024 8:01 am
Thejiral
(@thejiral)
RE: Longer print times than in cura
Have you had a look at minimum layer time in the filament cooling settings?
If you have turned that off or reduced it to a very low level, have a look at the speed settings which are found in the printer profile. Are the speeds the same as in Cura?
Opublikowany : 28/02/2024 9:10 am
Thejiral
(@thejiral)
Also check if you have some acceleration limits in place and if so, if they are lower in Prusa Slicer than in Cura.
Opublikowany : 28/02/2024 9:11 am
