Just updated to 2.6.1, and this first layer is baffling
Slavkosky
(@slavkosky)
I have never seen this before (been using PS w/my MK3s+ for a few years now).
- It looks similar to the effect the Pressure Equalizer gives you, except not at all 😆
- I have had my First Layer Speed hardcoded at 25mm/s for as long as I can remember
- I didn't see this in PS 2.6.1-rc1 either (with this same model and print settings)
I've attached my .3mf project file in case anyone wants to see if they can replicate this or find out what's going on here
This topic was modified 2 years temu 2 times by Slavkosky
i3 MK3S+
(stock)
- Powder-coated, Satin, & Garolite Sheets
- 0.25/0.4/0.5/0.6/0.8mm NozzleX
- 0.6mm Bondtech CHT
_____SL1S & CW1S (stock)
Opublikowany : 11/09/2023 9:53 pm
Is your part placed perfectly flat on the bed?
Opublikowany : 11/09/2023 11:31 pm
1 ludzie polubili
Hello
(@hello)
RE: Just updated to 2.6.1, and this first layer is baffling
3mf file has not attached it needs to be in a zip file
Opublikowany : 11/09/2023 11:42 pm
Yup, my money is on this one. Use the F key to make sure the object sits flat. This picture indicates it's at a tiny angle
Opublikowany : 12/09/2023 11:13 am
