Issues with travel along walls
IL3D
 IL3D
(@il3d)
Hi guys,
Prusaslicer has been my slicer of choice for years but now I'm not able to figure out what's happening here.
I get inconsistencies in what is otherwise a good print and I've noticed they appear where there's a travel movemente along the outer walls (see pictures).
I have a bowden setup and my retraction is set at 5mm at 40mm/s but there is no retraction, deretraction or wipe going on (apparently) in that area.
Can you help me sort this out?
Publié : 29/08/2021 7:46 am
Membre
What printer
Which printer?
Publié : 29/08/2021 4:47 pm
IL3D
 IL3D
(@il3d)
Anycubic Vyper
Anycubic Vyper.
Sorry I forgot to mention it.
Publié : 29/08/2021 5:23 pm
Swiss_Cheese
(@swiss_cheese)
can you post a Zipped up .3mf project file?
The Filament Whisperer
Publié : 30/08/2021 5:30 pm
IL3D
 IL3D
(@il3d)
3MF attached
bronco_
There you go! I really hope you have some insight for me 😀
Publié : 31/08/2021 6:12 am
Swiss_Cheese
(@swiss_cheese)
@il3d
I don't own an Anycubic however as I look through your .3mf I'm seeing to much plastic being extruded, and your images seem to be showing the results I would expect from this. I would try reducing the layer height to 0.25, and if you feel you need to have 3 perimeter walls I would reduce the extrusion widths to something in the 0.42 -0.45 range. the issue your reporting can actually be seen in several places before the print reaches the windows. currently the print is showing that its printing at 43 mm/s you might try reducing the speed to something in the 30 to 35 mm/s range this can be done quickly (if you choose) by changing the MVS to 3.0.  this might also help reduce the ghosting around the window mullions.
Good Luck, I hope this helps
Swiss_Cheese
Publié : 31/08/2021 6:04 pm
IL3D
 IL3D
(@il3d)
@Swiss_Cheese
Thank you for your reply.
I will try reducing the line width but the speed honestly I would expect the machine to be capable enough to handle. I have settled with these settings because I have to balance production time and final quality.
Anyway, I will experiment  and tweak some more...
Publié : 01/09/2021 8:54 am
Swiss_Cheese
(@swiss_cheese)
@il3d
I printed a test yesterday with the settings I suggested, but it was on a Prusa direct drive so it's not the same, I couldn't test on an Anycubic.
I'm sure the adjustments can be made though
Sorry I couldn't be of more help.
Swiss_Cheese
Publié : 01/09/2021 3:12 pm
IL3D
 IL3D
(@il3d)
settings
Will you be so kind to share a screenshot of your settings?
I'd appreciate it very much! Thanks a lot man!
Publié : 01/09/2021 9:21 pm
