Is there overlap between lines in the walls/perimeters ?
Gatze
(@gatze)
And I don't mean between infill and walls.
I'm trying to calibrate my printer (sidewinder X1), already did the e-steps procedure and printed a test cube.
https://3dprintbeginner.com/flow-rate-calibration/
This is my 'rough and fast' profile, I print with a .6 nozzle with a linewidth of 0.75 and a height of 0.5mm
I would expect the walls of the testcube being 2x0.75 = 1.5 mm (2 lines of 0.75mm)
But they are smaller. When I see this in the slicer:
Then my question is: is there some kind of overlap ? Because in the slicer is stated: 2 lines = 1.39mm and I expect 1.5mm ?
I can only find an overlap value between infill and walls, but not between lines in the walls or perimeters it self.
Hope the question is clear.
Questa discussione è stata modificata 4 years fa da Gatze
Postato : 14/12/2021 12:31 pm
Gatze
(@gatze)
RE: Is there overlap between lines in the walls/perimeters ?
Found the answer, important to know for calibration of the extrusion multiplier:
https://help.prusa3d.com/en/article/layers-and-perimeters_1748/
I sometimes switch between Cura and Prusaslicer, does anyone know if Cura does this in the same way ?
Postato : 15/12/2021 6:19 pm
