Is there a way to have different infills at different ranges of layers, like 100% from Z = 0.00 to Z = 50.00 and 20% above that?
Uffesa
(@uffesa)
Veröffentlicht : 29/08/2022 11:56 am
;+ěščřžýáíé=?>:"}{":>?>~,./';l';[]``
(@escrzyaie-l)
RE: Is there a way to have different infills at different ranges of layers, like 100% from Z = 0.00 to Z = 50.00 and 20% above that?
Hello, you can use modifiers -  https://help.prusa3d.com/article/modifiers_1767#modifier-meshes   I hope that will help you.
Veröffentlicht : 29/08/2022 12:01 pm
Sure. Read up on height range modifiers https://help.prusa3d.com/article/modifiers_1767#height-range-modifier
Veröffentlicht : 29/08/2022 12:44 pm
Alternatively, set the number of bottom layers to say 250 bottom layers (with 0.2mm layer height) and you will get 50mm of bottom layers which may well print better than 100% infill.
Veröffentlicht : 29/08/2022 6:36 pm
