Is there a 'top layer' custom gcode option?
I figured a new thread about this was appropriate instead of using my other thread, which is off topic.
Is there a slick, automatic way to add custom gcode to top infill layers? I would like to add a custom code to adjust my pressure advance at top infill layers only. I figure the slicer engine has this capability since it can change extrusion width at top infil layers, I was just wondering if there was a way to punch in my custom line as well. I figured it may be something such as an IF structure in the layer change custom gcode section. Or maybe it doesn't exist.
No, I won't be opening up and modifying every gcode file I make manually. I don't have that kind patience.
Napsal : 10/07/2020 7:00 pm
