Is there a setting for Bridge Infill in Prusa Slicer
Ira S
(@ira-s)
When using supports, there is a layer printed above the support material. I believe it is called Bridge Infill.
For some reason, it doesn't print as "dense" as a normal layer (there is a slight gap between each printed line of filament) but yet it is part of the model, not part of the support. It doesn't get removed when the support material is removed. A screen print of the layer in question from the slicer is attached.
Is there a way to eliminate the gaps or make them smaller? I looked through all of the advanced settings and couldn't find anything.
Thanks
Respondido : 25/09/2023 8:45 pm
RE: Is there a setting for Bridge Infill in Prusa Slicer
This doesn't feel right. Can you attach the project 3mf file so we can see STL and all your settings? Needs to be zip-compressed before the forum software allows you to attach it to a post here.
Respondido : 25/09/2023 9:14 pm
Ira S
(@ira-s)
Posted by: @fuchsr
Sure, attached!  Thanks.
Respondido : 25/09/2023 9:17 pm
Turn Thick Bridges off in Layers and Perimeters. That should do it.
Respondido : 25/09/2023 9:24 pm
Ira S
(@ira-s)
Posted by: @fuchsr
Looks like I need a version update to my PrusaSlicer to get that setting. I'll update and try it out. Thanks!
Respondido : 25/09/2023 9:34 pm
JimB
 JimB
(@jimb)
Posted by: @fuchsr
Posted by: @fuchsr
Thick Bridges is an advanced setting.  Be sure you are in advanced or expert mode.
Respondido : 26/09/2023 12:06 pm
2 les gusta
Mario Herrera
(@mario-herrera)
Miembro
So thx mate, it's works for me 👍
Respondido : 22/04/2025 5:13 pm
Snuffleupagus
(@snuffleupagus)
Miembro
Sometimes, I feel like we should start every new attempt to help with that as an opening line. 😋
Esta publicación ha sido modificada el hace 1 year por Snuffleupagus
Respondido : 22/04/2025 11:02 pm
mikerowesr
(@mikerowesr)
Miembro
Posted by: @fuchsr
Perfect! Thank you!
Respondido : 26/11/2025 5:31 pm
