Is it possible to have two different infill percentages?
buckeyestargazer
(@buckeyestargazer)
I'm trying to figure out a way to change the infill density in the middle of a model/print.  For example, I want the bottom half of a model to have 15% infill, and the top half to have 100% infill.  Is this possible?
Best Answer by sylviatrilling:
Yes, you can do this with a modifier mesh or a height range modifier. See https://help.prusa3d.com/en/article/modifier-meshes-custom-supports-and-other-magic_114258
Veröffentlicht : 07/03/2022 3:50 pm
sylviatrilling
(@sylviatrilling)
RE: Is it possible to have two different infill percentages?
Mk3S+,SL1S
Veröffentlicht : 07/03/2022 3:56 pm
ARU
 ARU
(@aru)
That should possible by inserting a modifyer (p.e. a slab and changing the infill pattern and/or density)
I'm using this when I place inserts by heat and would like to have a reinforced area for the screws and inserts
buckeyestargazer
(@buckeyestargazer)
Thanks.  I knew there would be a way but I couldn't figure it out.  The modifier is what I needed.
Veröffentlicht : 07/03/2022 4:38 pm
