Infill pattern as toplayer pattern
chrisb
(@chrisb)
Hi@all, is there a workaround or function in prusa slicer planed to use infill patterns like honeycomb to decorate the toplayer surfaces? Also stemp patterns would be nice.
Respondido : 09/09/2022 7:52 am
1 les gusta
RE: Infill pattern as toplayer pattern
Just set the number of top layers to zero.
Respondido : 09/09/2022 11:03 am
chrisb
(@chrisb)
thx fuchser, a nice option to see the regualar infill if i understand you right. but is there a possibility that the object is normaly closed by toplayers and only the last toplayer is for example a honeycomb pattern or loadable stamp pattern. would be a nice finish vor technical parts with flat toplayer surfaces.
Respondido : 09/09/2022 11:16 am
xiiii
(@xiiii)
you mean somthing like this?
in the ''Plater'' 3D editor view/preview on the right side, right click on your .stl name.
''Heiht range Modifier'' adjust where it Starts and Stops. (example: 10mm model : 9.80 - 10.00 layerheight 0,2mm)
right click on the Range like you did befor with the name and ''Layers and Perimeters'' + ''Infill''
below you can adjust now the infill something like 50% honeycomb + Top solid layers 0
you will lose one solid top layer so maybe adjust it in the printer settings if needed
Respondido : 19/09/2022 11:46 pm
1 les gusta
@chrisb — didn't see your message earlier but @xiii showed the most straightforward way to accomplish what you have in mind.
Respondido : 20/09/2022 5:42 pm
xiiii
(@xiiii)
looks like ''stamps'' can be made almost the same way. i used a cube 20x20x20mm and a test stamp 0.2mm height. print settings: layer height 0.2mm
right click on the cube-> ''Add negative volume'' -> ''Load'' -> choose the stamp.STL and open
left click on the stamp.STL(on the right side) and adjust the Z-Position to 9.90mm(1layer) or 9.80mm(2layers)
OR if you want the stamp filled with 50% honeycombe it would be :
right click on the cube-> ''Add Part'' -> ''Load'' -> choose the stamp.STL and open
right click on the stamp.STL(on the right side) and pick ''Layers and Perimeters'' + ''Infill''
set bottom solid layers, top solid layers and perimeters to ''0''
infill 50% honeycomb.  ''0%'' would be the same like with the''Add negative volume''
Respondido : 22/09/2022 6:17 pm
chrisb
(@chrisb)
@xiiii & @fuchser - thanks for your workaround adice (y) ! [solved]
Respondido : 27/09/2022 6:24 am
