Infill does not fill tapered profile
howard.b6
(@howard-b6)
Take a look at the attached file of a PrusaSlicer 2.4.2 slice from an .stl file created in Fusion 360. Simplify slices correctly so I know the .stl file is good.
Surely this is a bug in PrusaSlicer 2.4.2?
This topic was modified před 4 years 2 times by howard.b6
Napsal : 28/07/2022 10:34 am
jsw
 jsw
(@jsw)
RE: Infill does not fill tapered profile
If you would post the .stl (be sure to zip it) I would be glad to give it a look-see and see how it behaves on my setup.
Napsal : 28/07/2022 10:41 am
howard.b6
(@howard-b6)
See attached.  And thanks for your help.
Napsal : 28/07/2022 10:45 am
Going to need more than the stl file.  We are going to need your saved project file (File > Save Project As ) from PS.  As that will contain all your settings too.
I downloaded the stl and sliced it with my normal settings and the infill is working perfectly in that area for me.  That would suggest its something in your settings.
Napsal : 28/07/2022 11:18 am
jsw
 jsw
(@jsw)
Using my PS (currently 2.3.0) and using the gyroid infill pattern, which I normally use unless I have a specific reason to do otherwise, I get a more or less normal infill pattern on the tapered section.  I double-checked this with Cura to be sure.  Boosting the infill percentage from my normal 15% (above) to 90% (below) fills the void between the perimeters nicely and fully.
However, what caught my attention is that the threads in the barrel portion appear a bit wonky.
My hunch is that they will print as expected, however, and I'm doing a test print of the first few turns of the threads out of curiosity to see how it actually prints in real life.  I'm expecting kind of a sharp-edge profile on the threads.  Film at 11 (or when it finishes).
Napsal : 28/07/2022 11:25 am
Sliced fine for me. At least I don't see anything unusual.
Please upload your 3mf project file so we can check the settings.  In Prusaslicer, go to File/Save project as, to create the 3mf file. Zip compress it (right click Compress on Mac and WIn11, right click Send to/Compress on Win 10) to turn it into a .zip file, which you can attach to a post on this forum. The forum software does not accept 3mf files, it has to be a zip file. The 3mf contains the STL plus all your settings.
Napsal : 28/07/2022 11:27 am
jsw
 jsw
(@jsw)
Update, the test print finished as expected with good clean threads.
And, I personally prefer a raw .stl when diagnosing a print.  We know what settings produce a bad print, I want to produce a good print.
Napsal : 28/07/2022 11:29 am
howard.b6
(@howard-b6)
Here we go...
This post was modified před 4 years 2 times by howard.b6
Napsal : 28/07/2022 11:39 am
howard.b6
(@howard-b6)
Thank you all for looking at this.  After playing with the settings one at a time, I have now found the issue. 'Only infill where needed' was set. Unsetting it has resolved the issue.
Napsal : 28/07/2022 11:49 am
1 lidem se líbí
Yeah, I was just going to post this. Glad you found it on your own.
Napsal : 28/07/2022 11:55 am
jsw
 jsw
(@jsw)
I've seen that and wondered about it.  I've never tried it.  I'm curious about what it decides upon as to what infill is and is not needed.
Napsal : 28/07/2022 11:56 am
It only adds infill as needed to support overhangs. Kind of like support cubic does by default.  It's somewhere on the infill page in the Prusa knowledgebase.
Napsal : 28/07/2022 12:18 pm
howard.b6
(@howard-b6)
comment from @jsw
"I've seen that and wondered about it.  I've never tried it.  I'm curious about what it decides upon as to what infill is and is not needed"
I agree. Surely the choice of where infill is used or not should be controlled by a human.  The machine will fail if left to arbitrarily decide.
I would argue that to allow the option leads to inconsistent results and therefore the option should be considered a bug 🙂
This post was modified před 4 years by howard.b6
Napsal : 28/07/2022 12:20 pm
If you feel that way then surely you shouldn't be using a slicer at all and hand writing your gcode.
Napsal : 28/07/2022 12:43 pm
jsw
 jsw
(@jsw)
Seriously though, it might be good experience to try out other slicers, such as Cura and/or SuperSlicer and see how they do or do not meet your needs as well.
Napsal : 28/07/2022 1:00 pm
howard.b6
(@howard-b6)
comment from @jsw
Posted by: @neophyl
Not helpful.
Napsal : 28/07/2022 5:38 pm
