importing multiple stls at the same time and keeping alignment broken in 2.2.2
tweiner
(@tweiner)
I had this neat little trick.  When I designed a multi-color object, in tinkercad, I would export an stl for each color.  Then I would open prusaslicer 2.1.1 and import all of the stls at one time.  They would automatically keep their alignment and off I would go to print a multi-color thing.
I just tried to do the same with 2.2.2 and it centers each one messing up the alignment.
Is there a parameter I can tweak or do I need to go back to 2.1.1
Thanks
Veröffentlicht : 20/04/2020 9:05 pm
towlerg
(@towlerg)
RE: importing multiple stls at the same time and keeping alignment broken in 2.2.2
I assume 2.2.2 is a typo, AFAIK 2.2.0 is the latest, released 21 March.
I tried importing several objects at the same time and they are placed as you wanted. If you attach an zip file I'll try it. I seem to remember when playing with Rainer's two colour technique PS asked weather the objects where separate or not, I'll have a play and get back to you.
Veröffentlicht : 21/04/2020 1:52 pm
tweiner
(@tweiner)
Thank you for your reply.  yes a typo of course, I meant 2.2.0
Just tried it again and it works as it should.  So probably a problem created by the user (me)
Thanks.
Veröffentlicht : 21/04/2020 3:29 pm
