Imperial Check
I'm new (two weeks) to the 3d world and really know very little of the technology and the nomenclature, so please bear with me.
I design (model) in Siemens NX in imperial (inches), when importing an SLT file, Slicer (2.4.1) would ask if I wanted to calculate from metric to inches.
However, my last import only brings my SLT file in the metric format with no question of units preference.
I can't find the setting I must have turned off...can someone point me in the right direction.
Much Thanks!
You always have the option to import in imperial units on the file menu.
RE: Imperial Check
Thanks so much!
I did even look under the file/import assuming it would not yield any favorable answers.
Thanks again, be safe
RE: Imperial Check
I can design in Metric and it is scaled wrong in Prusa. I can design in inches and it is scaled wrong in Prusa. I either have to set the scale factor to 1000 or 39.37 depending on what pops up. I installed PrusaSlicer with the imperial option as well as metric, I wonder if there is a bug there. Maybe a devious plot to convert the US away from Imperial...
