Ignore bridge? Inset text.
BIGRED
(@bigred)
Under the blue bridging, there is 0.2mm inset text. Is there anyway to tell the slicer to ignore it, just print over it like it's not there?
I'm re-slicing a few of my models, and this has always bugged me. Thought now is a good a time as any to try and nut it out! Cheers.
Best Answer by BIGRED:
Ok, figured it out, you need to set the layer above it to have 'bottom solid layers: 0' using a height range modifier. Knew I would get it in the end, SOMEHOW!
The top one is done with traditional bridging set to 1.3, the bottom is with the method above. Give a deeper more contrast look, and easier to read the text. Still doesn't look as good as I had it, but it'll do for now.
Postato : 16/05/2024 8:44 am
RE: Ignore bridge? Inset text.
Not really no.  Its been requested on the Prusa Slicer github for example https://github.com/prusa3d/PrusaSlicer/issues/10849   being a recent one.
You could experiment with modifiers but in general that's just the way PS works.
For stuff like this where I absolutely have to have an unbroken layer I use an older version of Super Slicer as theres settings in there that you can alter to control this.
Postato : 16/05/2024 9:38 am
1 persone hanno apprezzato
BIGRED
(@bigred)
I found that after I got frustrated... cheers! I did put a modifier in and increased the extrusion ratio of the bridging for that section to 1.3. Makes it look better at least. I had better results with my old slices, but having to re-slice everything due to the 3.5 upgrade. Getting there slowly but surely!
Postato : 17/05/2024 4:14 am
BIGRED
(@bigred)
Postato : 17/05/2024 10:07 am
felice
(@felice)
Utenti
Could you let me know what version of superslicer you use for this, and what the setting is?
Postato : 15/09/2024 11:29 am
