Ignore bridge? Inset text.
Under the blue bridging, there is 0.2mm inset text. Is there anyway to tell the slicer to ignore it, just print over it like it's not there?
I'm re-slicing a few of my models, and this has always bugged me. Thought now is a good a time as any to try and nut it out! Cheers.
Best Answer by BIGRED:
Ok, figured it out, you need to set the layer above it to have 'bottom solid layers: 0' using a height range modifier. Knew I would get it in the end, SOMEHOW!
The top one is done with traditional bridging set to 1.3, the bottom is with the method above. Give a deeper more contrast look, and easier to read the text. Still doesn't look as good as I had it, but it'll do for now.
RE: Ignore bridge? Inset text.
Not really no. Its been requested on the Prusa Slicer github for example https://github.com/prusa3d/PrusaSlicer/issues/10849 being a recent one.
You could experiment with modifiers but in general that's just the way PS works.
For stuff like this where I absolutely have to have an unbroken layer I use an older version of Super Slicer as theres settings in there that you can alter to control this.
I found that after I got frustrated... cheers! I did put a modifier in and increased the extrusion ratio of the bridging for that section to 1.3. Makes it look better at least. I had better results with my old slices, but having to re-slice everything due to the 3.5 upgrade. Getting there slowly but surely!
Could you let me know what version of superslicer you use for this, and what the setting is?
