How to use the 'stealth' printer limits of Prusa Slicer
zapta
(@zapta)
In Prusa Slicer there are two sets of machine limits, Normal and Stealth. When I generate the gcode file it uses the values from the Normal set. How do I change it to use the values from the Stealth set?
Prusa slicer screen
GCode file:
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.42mm
; first layer extrusion width = 0.50mm
M73 P0 R43
M73 Q0 S46
M201 X10000 Y10000 Z400 E5000 ; sets maximum accelerations, mm/sec^2
M203 X350 Y350 Z12 E100 ; sets maximum feedrates, mm / sec
M204 P7000 R2500 T7000 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X10.00 Y10.00 Z2.00 E10.00 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
This topic was modified před 9 months by zapta
Napsal : 01/08/2025 5:18 pm
RE: How to use the 'stealth' printer limits of Prusa Slicer
You dont.
Stealth mode was a Prusa creation, it was added specifically to their printers and isn't/wasn't part of any official specification (not sure if this is still the case).  As such there are no specific gcode commands for stealth limits, (ether as Mxxx or as a parameter to the standard M limit codes)
As the choice to run in stealth is set on the printer and only prusa printers were concerned with this there was no need to set them in the top, in fact only the normal ones can be included in standard gcode because you can only include 1 set using normal M commands.
You may be asking 'then how does the printer slow down in stealth mode then'.  Answer is that ALL of the settings from your profiles are stored at the end of every gcode file generated.  Your stealth capable printers can read those just as easily as any other line of text.
For example, from a gcode file I had kicking around for my Mk3.
; machine_max_acceleration_e = 5000,5000
; machine_max_acceleration_extruding = 1250,1250
; machine_max_acceleration_retracting = 1250,1250
; machine_max_acceleration_x = 1000,960
; machine_max_acceleration_y = 1000,960
; machine_max_acceleration_z = 1000,1000
; machine_max_feedrate_e = 120,120
; machine_max_feedrate_x = 200,100
; machine_max_feedrate_y = 200,100
; machine_max_feedrate_z = 12,12
; machine_max_jerk_e = 1.5,1.5
; machine_max_jerk_x = 8,8
; machine_max_jerk_y = 8,8
; machine_max_jerk_z = 0.4,0.4
Note the 2 sets, one is normal the other stealth.
Napsal : 01/08/2025 5:32 pm
1 lidem se líbí
zapta
(@zapta)
Thanks @Neophyl, this solves the mystery.
Is there a gcode to switch the printer to the stealth mode, something I can include in the startup gcode?
Napsal : 01/08/2025 6:08 pm
Not as far as I know but I'm not really familiar with any additions they may have done for the Xl's. Core1 etc as I don't own one.
If you want to decide the speed at slice time the simplest thing is to create an extra printer profile and set the normal speeds in there to the stealth ones. Then slice with the appropriate printer selected. No need for a switch then. Of course the normal way is to just slice using a Print profile that has suitable speeds for all the moves set as you like rather than relying on the printer maximums (which some printers don't even use anyway)
btw the reason I know this sort of stuff is I regularly skim the Prusa Slicer github repo. For example this now closed issue https://github.com/prusa3d/PrusaSlicer/issues/6161
For a gcode command to be supported it would first need implementing in whatever printers firmware and then in the slicer to match. These sorts of requests have to be made to the firmware providers. As yet you haven't mentioned what printer you are using. Prusa printers firmware githubs are located here for the older boards (einsy) https://github.com/prusa3d/Prusa-Firmware/issues and here for the newer ones like MK4.XL (Buddy Board) https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
There are a few existing for stealth mode switching on the Buddy repo already but they seem to be asking for control via Prusa Connect or on a schedule for overnight use.
The older firmware repo from a cursory search showed this one https://github.com/prusa3d/Prusa-Firmware/issues/2477 as the most relevant. There are others.
Napsal : 01/08/2025 6:44 pm
zapta
(@zapta)
Thanks @Neophyl, my printer is CORE One so xBuddy controller.
I would expect it to have a gcode command to control its mode.
Napsal : 01/08/2025 7:19 pm
_KaszpiR_
(@_kaszpir_)
Isn't it related to a StealthChop on newer printers? See https://help.prusa3d.com/article/buddy-firmware-specific-g-code-commands_633112 gcode M569, some of them have it enabled by default already mini).
Napsal : 01/08/2025 8:13 pm
zapta
(@zapta)
Posted by: @_kaszpir_
It seems that a change in the LCD stealth mode setting invokes M9140 or M9150.
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/818d812f954802903ea0ff39bf44376fb0b35dd2/src/gui/MItem_tools.cpp#L170
And according to ChatGPT (?) these commands control also the Trinamic StealthChop mode on all axis.
I turned the stealth mode on the LCD and am trying it now as my default printing mode. So far I like it.
Napsal : 02/08/2025 7:20 pm
_KaszpiR_
(@_kaszpir_)
in that case it does something different:
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/src/marlin_stubs/PrusaGcodeSuite.hpp#L137
which leads to
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/src/marlin_stubs/M9140_M9150.cpp#L21
and finally:
https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/master/lib/Marlin/Marlin/src/module/planner.cpp#L155
so it just sets different speeds only, and not touching StealthChop?
Napsal : 02/08/2025 7:42 pm
zapta
(@zapta)
It's possible that Prusa's 'Stealth mode' and Trinamic's 'Stealth Chop' are two independent concepts.
'Silent mode' would be a better name in my opinion, regardless if it uses Stealth Chop or not.
Napsal : 02/08/2025 9:52 pm
