How to use the actual filename instead of the body name, when slicing .3mf files
Alberto Farfugli
(@alberto-farfugli)
In fusion 360, if I have a body called "body1", save it as stl file and name that file "Ciaopoveri.stl", when I slice it with prusaslicer, the [input_filename_base] will be "Ciaopoveri".
If I save the "body1" as .3mf instead of stl, and name that file "Ciaopoveri.3mf", when I slice it, the [input_filename_base] will be "body1".
I would like to have the actual filename ("Ciapoveri") in both situations. I know this was the default behavior before 2021 ( https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/prusaslicer-output-filenames-for-stl-vs-3mf/), but is it possibile to do know?
Opublikowany : 29/11/2024 7:57 pm
RE: How to use the actual filename instead of the body name, when slicing .3mf files
I'd just change the body name in Fusion.
Opublikowany : 01/12/2024 11:25 pm
