How to turn off variable layer feature of PrusaSlicer?
Fatih Hamırcu
(@fatih-hamircu)
I'm using mosaic palette pro 3. my prusa settings are as follows.
G21 ; metric values
G90 ; absolute positioning
M82 ; set extruder to absolute mode
;P2PP PALETTE3_PRO
;P2PP PALETTE3_PRO
;P2PP PRINTERPROFILE=12345678901234567890123456789012
;P2PP SPLICEOFFSET=40
;P2PP MINSTARTSPLICE=130
;P2PP MINSPLICE=90
;P2PP EXTRAENDFILAMENT=150
;P2PP LINEARPINGLENGTH=350
;P2PP MATERIAL_DEFAULT_1_2_1
;P2PP MATERIAL_PLA_PLA_2_1_2
;P2PP ABSOLUTEEXTRUDER
;P2PP SIDEWIPELOC=X254
;P2PP SIDEWIPEMINY=45
;P2PP SIDEWIPEMAXY=195
;P2PP SIDEWIPECORRECTION=1.0
;set SIDEWIPEMAXY to the same value as SIDEWIPEMINY
;P2PP SIDEWIPEMAXY=45
;set WIPEFEEDRATE is required to override default value!!
;P2PP WIPEFEEDRATE=200
;P2PP PURGETOWERDELTA=0
;P2PP FULLPURGEREDUCTION
;P2PP WIPEFEEDRATE=3000
;P2PP AUTOADDPURGE
After I slice, I get the following message as a compile warning:
Variable layers may cause issues with FULLPURGE / TOWER DELTA
This warning could be caused by support that will print on variable layer offsets
What I'm aiming for is to turn off the variable layer feature. How can I turn off this feature?
Note: I am using PrusaSlicer 2.7.1 based on Slic3r edition on Windows machine.
Thanks in advance
Best Regards
Best Answer by FoxRun3D:
Prusaslicer does not by default align supports with object layer heights. See the end of https://help.prusa3d.com/article/support-material_1698 for an explanation. I'm not aware of any way to force it unless you can use the "synchronize with object layers" option (see link above).
Respondido : 19/12/2023 7:58 am
Fatih Hamırcu
(@fatih-hamircu)
RE: How to turn off variable layer feature of PrusaSlicer?
UPDATE:
the other error is
Respondido : 19/12/2023 12:27 pm
Respondido : 19/12/2023 6:07 pm
That is the only way to turn it off.  However that is only allowed when support contact distance is set to zero, ie you are using soluble supports. So basically you can only use it for models that don't have supports.
Respondido : 19/12/2023 6:15 pm
