How to make Prusament (and other filament presets) to other printers
jphalip
(@jphalip)
I'd like to use the Prusament preset (and others) with a printer other than my MK3s. In this case it's for a Voron 2.4.
How could I do that? Do I have to make a separate copy first? If so, how can I then make that copy available to the other printers.
Veröffentlicht : 11/11/2022 1:27 am
RE: How to make Prusament (and other filament presets) to other printers
There are several threads about this already.  Such as https://forum.prusa3d.com/forum/prusaslicer/how-to-make-filament-profiles-available-with-custom-printer/?language=cs
or https://forum.prusa3d.com/forum/prusaslicer/filament-profiles-3/?mode=grid
https://forum.prusa3d.com/forum/prusaslicer/filament-preset/
https://forum.prusa3d.com/forum/prusaslicer/prusa-2-2-0-does-not-show-filaments-tab-in-configuration-assistant/
but basically you have to install a printer that CAN access a filament, like a Prusa MK3, then copy it.  Then sanitize it to remove the printer specific LA stuff from the filaments custom gcode section, then make sure the compatible printers and print profiles sections are clear and then detach it from a vendor space/system preset and then save it again once thats all done.
Theres nothing special about filament profiles , its easier to just modify an existing generic one usually.
Also once you have your nice new custom profiles dont forget to make a backup of them all by exporting a config bundle.
Veröffentlicht : 11/11/2022 8:14 am
