How to get rid of supports in tiny holes?
samuel-t
(@samuel-t)
Hi
How can I get rid of the supports in the tiny holes? Paint on blockers don't work in this case - and I need the other blockers. Thank you very much for your help.
Best Answer by Neophyl:
Samuel, you can , there is a function in the paint tool called 'clipping', with it you can remove obstructing parts of the model to 'see' otherwise inaccessible areas.
You might want to read the PS knowledge base articles https://help.prusa3d.com/article/paint-on-supports_168584
Veröffentlicht : 09/12/2023 9:09 pm
RE: How to get rid of supports in tiny holes?
If you could save your model in prusa slicer as a project file, (Files.Save project as) then compress the resultant .3mf file as a zip file, then attach the zip file to your next post, we can try and help you, rather than guessing what may help.
Veröffentlicht : 09/12/2023 11:13 pm
Hello
(@hello)
I'd use paint on supports where j would need it but like Joan said we carnt do much without the 3mf
Posted by: @samuel-t
Hi
Veröffentlicht : 09/12/2023 11:22 pm
samuel-t
(@samuel-t)
Hi both
Certainly, I have attached the project file for your review. I've been considering the option of simply painting the support, as it may not be necessary on many surfaces. Or adding a negative volume? Not sure, but thank you very much for your support - much appreciated. Perhaps there's a more straightforward solution, and I am generally eager to find a resolution as this isn't the first time I've encountered this challenge.
Best
Sam
Project: gatorclamp-v5
Veröffentlicht : 10/12/2023 10:01 am
Hi Sam,
Try this
gatorclamp-v5 JT
Joan
Veröffentlicht : 10/12/2023 11:39 am
Crab
 Crab
(@crab)
You can paint on supports and you can paint areas where you DO NOT want supports.. Don't think you can do it when you let the slicer add supports.. but just choose "for support enforcers"
Veröffentlicht : 10/12/2023 4:24 pm
samuel-t
(@samuel-t)
Thank you @JoanTabb - I see you worked with paint on support, I'll follow that path then as well in the future.
@Crab - Yes, I'm aware of blockers, but that doesn't solve the problem here because you'd not be able to reach the overhang in the tiny hole with the blocker brush.
Veröffentlicht : 10/12/2023 5:19 pm
Veröffentlicht : 10/12/2023 5:57 pm
3 weiteren Personen gefällt das
samuel-t
(@samuel-t)
That's what I was looking for, thank you very much Neophyl!
Veröffentlicht : 10/12/2023 6:05 pm
