How to generate x3g-files
For an old CTC printer, I need to generate x3g output files. It should somehow be possible with the Prusa slicer, but I can't find out how. I found out there is a program named gpx.exe, and I managed to install it and tried to convert my gcode file. Yes, it works somehow, but the result was not correct. The printer tried to print outside of the bed, did not heat the platform and did not extrude the filament. Just the movements seemed to be correct.
I hope that when the x3g would be produced directly in the slicer, the result would be better.
Thanks, and greetings
Hans
Respondido : 16/07/2023 2:56 pm
RE: How to generate x3g-files
Prusa slicer doesn't support that output format. It's proprietary.
Respondido : 18/07/2023 12:04 pm
