How to disable save project settings?
tanj666
(@tanj666)
Is it possible to stop the slicer form asking to save updates to projects everytime I use it?  I do nice simple models, not these project things.  The last version didn't annoy me asking to save projects.
And how do you stop those really annoying 'paper-clip' things appearing - "Oh it looks like a log, do you want some scented paper to wipe with?"
Veröffentlicht : 31/12/2021 12:14 pm
RE: How to disable save project settings?
If you open Prusa Slicer 2.4, and select the Configuration drop down menu of the tool bar at the top
then select Preferences, you can deselect the save changes option about two thirds of the way down the 'General' tab
and
If you select the 'Gui' tab, you can disable 'Tip of the day' in there
Veröffentlicht : 31/12/2021 4:10 pm
tanj666
(@tanj666)
Thanks for the reply, Joan.  I had already tried all that and I still get asked to save the project when I close prusa slicer.  Any other suggestions other than giving up in frustration and living with it, consider it a featurette (aka a feature that you don't want to take advantage of - aka a bug)?
Veröffentlicht : 02/01/2022 11:33 am
Darthmonkey
(@darthmonkey)
I usually don't save the work either, and it prevents shutdown if I have one, let alone 3+ prusa slicer windows open. I found this which points to an update in the latest version. Should be fixed soon...
https://github.com/prusa3d/PrusaSlicer/issues/7114
Veröffentlicht : 19/02/2022 12:29 am
mathlad
(@mathlad)
I just kill prusaslicer from the task manager (ctrl-shift-esc). Inelegant, but it gets the job done.
Veröffentlicht : 20/03/2022 9:37 pm
Swiss_Cheese
(@swiss_cheese)
@tanj666
Just run the prusa-slicer-console version, it's exactly the same program. when your done just click the X to close the console window and slicer will just go away, it won't ask you a thing, no matter what you changed. it's my preferred way to run 2.4.
Regards
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 21/03/2022 12:03 am
Brad
 Brad
(@brad-11)
Mitglied
If I am reading this correctly, you were having the same issue I was. The save dialog is the set as the default closing operation. Must have selected the wrong thing at some point.
The solution for my issue was counterintuitive. I went to Configuration/Preferences/General. Then I selected "Ask for unsaved project changes". This causes the basic popup to show up, rather than the save dialog, on close. Now, the first time you close a project, you can select "Discard" and to "Remember my choice" from the popup.
Veröffentlicht : 06/01/2025 10:07 pm
Dave11674
(@dave11674)
Mitglied
this issue is still happening
how can we fix this >?
everytime i close the sliver software  it ALWAYS asks me to save my project !!
i need it to stop please, ive unticked the box in the settings
but still it pops up to save as !
dave
Veröffentlicht : 16/02/2026 2:39 am
